The last three times that i have driven my truck for any length of time (over one hour) on the highway running around 70 75 mph I have gotten a slight vibration in the engine and it will come and go in a cycle maybe 15 seconds or so then run smooth again. It runs and starts perfect around town no problems, it will do this for ten minutes or so then quit, also twice when I started it after running a while it has really serged at idle like a gasser with a BIG cam.
The last time I checked my pressures they were a little low and I new I needed a new lift pump. Sunday I installed a new Lp and filter and found the check valve to be bad on the old one plus 350 k on it.
Today I pulled the dump trailer about 40 miles to the dump then 5 miles from home the truck starts to shake like a bad tire or something I let off the throttle and it stops then i get back up to 70mph and it happens again, after the 3-4 th time I let off and the engine stays at rpm for just a second with my foot off of the pedal I get off at my exit and all is well again.
I looked everything over for fuel leaks but every thing is dry
I havn't checked the pressure on the new pump yet but will try to get to it tomorrow
Any Idea's
Joe
Any Idea's
Joe
