Engine/Transmission (1998.5 - 2002) Injection pump puller bolt size?
Engine/Transmission (1998.5 - 2002) transmission leak
mikeberry
I have been searching for awhile. I know a member posted the bolt size needed to build the puller. I have a puller but need the correct size bolts.
they are 10 X 1. 5 inch threads depending on how thick your puller is, you'll need them about 3-4" long (two of these)
Todd did they go to a bigger bolt on the Vp44? I know the 12 valvers was 8mmX 1. 25 Pitch about 3 1/2 inches long... .
It is an 8mm * 1. 25 pitch. You will need to get atleast grade 10. 9. You probably want around 2 1/2" or 3" long.
I used two of the bolts that hold the intake horn on. They are the same thread, perfect length, and you already have them off at that time anyway. .
Matt
