Purchased "factory" reconditioned injectors from Cummins Cal Pacific. After installation engine missed badly. Took back to Cummins and they spent all day trying to find the problem. After many $s I pulled injectors myself and took to Injector shop and they found three badly out of specs. They redid them for only a few dollars and the problem was solved. Should have gone to them in the first place.
I had also had Cummins install rebuilt fuel pump. Fuel milage droped from 18-19 to 16 mpg.
I suspect the timing may not have been set correctly when Cummins installed the pump.
Although the pump is under warranty, I'm reluctant to take it back. Everytime I go there it costs a fortune and the work is not good. Would take it to Jim Leonard, but he moved out of the area.
Can I check the timing myself? Seems I recall a thread about that. Its VE pump on 1990 unit.
