I would not advance it too much more (if at all) at this point.
You do have a possible issue with the reman nozzles though...
You can actually have a very large variation in pop off pressures, even with brand new ones... . someone once told me that even bosch can have as much as 8 bar variation.
I have not personally tested that theory, but you never know.
If I have any choice I buy new not reman nothing... it never fails that by the time you finish re-fixing, re-moving and re-installing you're further ahead to just go new right off the bat...
It may be a load of bad fuel, it may be a couple of "dribblers" among the injectors as well.
The only thing that really changes when putting the truck in gear is the RPM... on mine it likes to idle around 750 RPM in gear. If it gets a tad hazy, I shift to "N" and it goes away. This is caused by the cylinders cooling down and the raw fuel not being fully burned.
If you advance the timing too much cylinder pressures rise dramatically.
You VE pump is now trying to cram fuel thru a nozzle that is undergoing steep pressure spikes... basically it will (I would think) further stress the pump if pushed too far.
Generally you can run around 17*advance as an upper end with some decent reliability.
I'd run a health double dose of fuel additive designed for detergent, cetane, and lubricity thru it.
You can run Howe's Meaner Power Cleaner, Stanadyne, or Lubrication Engineers thru it.
Bob
Bob
