Today i am driving my pickup and noticed it felt a little different on the bottom end. Running a little different. Hard to explain but right off the bottom it felt like a motorcycle does with the choke on. Well I continue on and noticed a huge cloud of white/blue smoke rolling out the tailpipe and no power. This only happens when you are decelerating and then just crack open the throttle 10 percent or so and hold it there. Power is normal in every other throttle position. So I go right to the dealer and take the service manager for a ride. Great guy by the way, best service guy I have ever dealt with. So he says he thinks its fuel not antifreeze or oil. He thinks its either a pump or a bad injector. So straight home i go and swap out the injectors and everything else it did not come with from the factory. No change. Checked oil for antifreeze and its clean. Does this sound like a VP44 on its way out?
