Putting DDP stage II injectors in. . . I have three different thicknesses of copper sealing washers: 0. 5mm, 1. 5mm, and 2. 25mm.
My stock injectors had the 2. 25mm washers. The DDP ones came with 0. 5mm washers but did not crush enough to seal the bore and so resulted in blowby around the injector. They put the new injectors approximately 0. 5mm deeper into the cylinder.
The next thickness, 1. 5mm, puts the new injectors approximately 0. 5mm shallower. They seal well at idle, but I haven't had the chance to road test.
The final thickness, 2. 25mm, would put the new injectors approximately 1. 3mm shallower. If I had a 1mm washer, the new inectors would be at stock depth, within a few tenths of a mm. My question is, does anyone have a spec on injector tip depth for maximum atomization and combustion?
