I installed my 275 injectors and now I have a leak. The #6 injector is appearantly leaking where the line goes into the head. The leaking diesel is one thing, but then the truck has crank for about 30 seconds to start after sitting for an hour. I did not tighten the nut with a torque wrench but it is tight. I decided to put a new o-ring on the injector tube in the hopes the leak would stop but it didn't.
Has anyone had a similiar problem and found a solution? I may remove and reinstall the injector just to be sure that everything lines up correctly as the #6 injector was not the easiest to reach.
