Details here: TDR Privileges
dezeldog I want add injectors to the edge ez , but still can't decide, if go with 275 or dd I. Hard to say, if $250 more for DD I is worth it. And going with DD II and keep EGT on safe level of 1300* with OEM 3" exhaust maybe will be impossible. I don't know. Thanks god we have this great TDR site, here we can find lot of answer. Now my search are injectors.
M Evan you and I are on the same page I've been thinking about the EZ. From what I've read everyone seems to like that set up. I don't know if I'm going to use the 275s or the 1s. Too much I TRIED TO BY-PASS THE CUSSING FILTER to think about.
Wow! thats alot of folks doing injectors. I just did my second set and it took less than half as long and the engine was hot... . Injectors are great. To all you EZ buyers. Its only a few bucks more for the comp and it gives you more room than you will ever need. If you get a wild hair I upgraded to the drag comp for 60 dolars. 275s and the comp or dd1s or 2s are plenty of power and probably as far as most would ever want to go. The comp is an EZ if you dont hook up the pump wire. If you do hook up the wire it has the capability of being a balls to the wall fueling box. Ive raced a few people with the comp and some 275s and have yet to be spanked.
