I just put my 275's in a couple months ago - was my first injector R&R. Here are a few observations/lessons learned:
1) I could get a torque wrench w/ crow's foot on all the lines but #6; tightened that one by feel.
2) Definitely remove the rear engine lift hook for better access to #5 and 6
3) if you really want to be precise with the torque using a crow's foot, you have to calculate the lever effect based on the actual crow's foot and torque wrench you are using. You have to make a couple of measurements and calculate the applied torque. It's not absolutely necessary as others have mentioned once you get a feel for it.
4) Snap-On makes a custom injector puller with slide hammer which works like a charm on cylinders #1-4, a special low profile injector puller which works awesome for #5 and 6 (the slide hammer won't fit), and a custom transfer tube puller for our engines which made the job very easy and low-risk of damage caused by improvising with other tools. I highly recommend them, and look at it like an investment, esepcially if you foresee messing with injectors in the future.
5) I highly recommend pulling all the transfer tubes out, cleaning them, and putting new o-rings on. They are cheap and available from Cummins in a 10-pack for a couple bucks.
6) When bleeding prior to re-start, leave #3 and 4 fuel lines loose (hand tight, and then back off a little). Put a shop towel underneath the lines to catch fuel drippage. Cycle the lift pump several times, and then crank the engine several times, checking the shop towel to see when fuel is present. When you see fuel, tighten them up and the engine should start. I made the mistake of continuing to crank the engine after I had seepage and it still wouldn't start. As soon as I tightened those two lines up, it started right up. The whole job can be done by yourself.
7) Definitely consider checking/adjusting the valves while you have the valve cover off, whether you think it needs it or not; mine were all in spec, but a little on the loose side. Readjusted them towards the tight side, and made a noticeable improvement in power
Good Luck - it's not too hard of a job, and once you do it once, then next time will be much quicker.
