nickleinonen said:how is carbon around the outside of the injector going to cause knock??? i can see it causing a knock if it is on the tip and distorts the spray pattern, but if it is up from there in the part that is inside the cylinder head below the copper crush washer that should in no way cause knock...
something seems very fishy about that diagnosis to me. .
Those pictures looked like mine on my thread here:
https://www.turbodieselregister.com/forums/showthread.php?t=136945
As far as the carbon build up, Industrial Injection hooked up my old injectors to a test stand that would pump up to +/- 5,000 psi solution through the injectors while an electric circuit activated the solenoids. Only at at 5,000 psi did my injectors actually start spraying; below this pressure the injectors were just dribbling or had a really pathetic 1/2 ***** spray pattern. Granted that the test stand was made for older style injectors, but it was enough to show what was happening with mine.
The surprising thing (to me, but maybe normal to the diesel experts) was that when the injectors were taken apart, there was carbon flakes INSIDE them. I wouldn't know how an additive would take care of this unless you run the truck really hard such that high rail pressures were maintained all the time to break this carbon up.
