Had the ez on setting 4 and started to notice puddles of diesel under the truck. Took the ez off and it was dry. Put it back in on setting 2 and started seeing puddles again (smaller this time). So I took the ez off until I can get this figured out.
It doesn't make much sense to me. I can run it just as hard as I want without the ez and no leak. Put the ez on and be very gentle and it still leaks. On setting 4 it would even leak at idle.
Anyone have any ideas? I pulled the valve cover and checked the torque on the one injector bolt I could reach without removing the rocker and they were all at spec.
Thanks.
Kevin
PS I REALLY need my power fix back:{
Thanks.
Kevin
