Injector leak only with ez
Pyrometer and Boost install on 04.5 600
Fuel everywhere under the hood!!!
Had the ez on setting 4 and started to notice puddles of diesel under the truck. Took the ez off and it was dry. Put it back in on setting 2 and started seeing puddles again (smaller this time). So I took the ez off until I can get this figured out.
It doesn't make much sense to me. I can run it just as hard as I want without the ez and no leak. Put the ez on and be very gentle and it still leaks. On setting 4 it would even leak at idle.
Anyone have any ideas? I pulled the valve cover and checked the torque on the one injector bolt I could reach without removing the rocker and they were all at spec.
Thanks.
Kevin
PS I REALLY need my power fix back:{
I had this problem it was where the line hooked the injector,I snugged it up. that was over 10,000 miles ago without repeat. I popped the hood with it running to find the leak.
