Engine/Transmission (1994 - 1998) Injector Manifold Return Line -Wanted
2nd Gen Non-Engine/Transmission should steering be stiff
I assume you mean injection pump fuel return line, the one that comes off the front of the pump at the engine side and runs behind it to the metal line leading back to the tank. There are places you can get the rubber portion of the line, needs to be diesel rated and is 5/16" ID as I recall.
I thought he was talking about the metal return line that runs from one injector to another then back to the filter housing. I would think that's a Cummins or dealer part only unless you can find a used one.
Scott
