Engine/Transmission (1998.5 - 2002) Injector Nozzles
Any body running a set of 75 horse jammer injector nozzles? Thinking about
getting a set wondering is there a downside to them? Just want to give it a swift kick in the pants :D not nuke it!!!!!!!!!! :( Also will egt's run high
I pull some decent sized loads on a stock trailer.
Happy Thanksgiving!!
Thanks for the help!!!!!!!!!!
I run the 100hp jammers and have had good luck with them. I can keep my drag comp on kill and my egt. s are still ok. I dont put any trailers though so I can tell you there. I dynoed right at 400hp w/ my setup.
Dan
I was wondering the same thing. Although I was thinking about the 150hp tips.
I will have to change out my turbo eventually, so I might as well go for broke with the tips.
DRiddel, if you dyno'd at 400 then I'm thinking I should be at 340-350.
I didn't get the opportunity to dyno yet.
Hey Snidley, is your truck an auto or manual? Just wondering what turbo your truck has, and if you have any other boxs or anything. I have the jammer 4's and a phat shaft 62/14, i just got it done a week ago, and so far i love it. With the box off i can just touch 1100 degrees at about 110 mph. I have been happy with the injectors, but i dont have anything else to compare to besides stock ones. Good luck!
Kevin you sound like the person I need to talk to. I see in your profile your runing a superchips (tuner i expect)? You would know that I have been running one to If my truck info was displayed on my post. Not sure why it's not showing that, sorry about that. The reason that Im considering injectors
is that Im not to happy with the programmer. Mine seems to make truck run
rough, more power yes :) But hammers like it's going to fly apart :( Does yours cause this?? This is the only box I have ever had. My Turck is pretty much stock. 02 HO,6speed,3500,4x4. 4. 10rear. straight piped, no slincer ring and a waste gate elbow a buddy gave me out of an edge ez. I want to stay preety mild for now daily driver and use it to farm. I want just enough power
till it will fun to drive but hard to kill!!!!!!!! Wondering about injectors 50 or 80
hp.
Thanks for the help man!!!!!
Jammer Nozzles
I run the Stage Three Jammers (100 hp) And I am satisfied with them. No other modifications besides a straight pipe on my 99 one ton. I would recommend them to anyone looking for cheap HP. They smoke pretty bad though. and mileage went down 2 mpg.
I have never had any problems with smoke. Even with the comp on a low setting. 5x5 is a different story :-laf
