Archived injector problem ????
Archived 2011 frame rails
I was pulling a boat on the interstate at 60 mph when engine started missing. Could only run about 45 mph in 5th gear. It would not pull in 6th gear. Limped home. Changed fuel filter and air filter. No help. Very loud ticking noise coming from engine. Could I have lost an injector. Fuel preasure is 20 lbs.
06 207,000 miles
p-bar
cycled key off-on three times, still shows miles. nothing about codes. Will a 06 show codes when you cycle the key.
No white smoke. I had a guy hook up his smarty and got these codes
0237
0236
2509
0193
0243
0148
0251
0483
2149
What do all these mean?
P0236 Turbocharger Boost Pressure Sensor Performance / Rationality
P0237 Turbocharger Boost Pressure Sensor Low
P2509 ECM/PCM Power Input Signal Intermittent
P0193 Fuel Rail Pressure Sensor High
P0148 Fuel Delivery Error
P0251 Fuel Injection Pump Mechanical Failure Fuel Valve Feedback Circuit
P2149 Fuel Injector Group 2 Supply Voltage Circuit
Is it the injection pump that is bad or an injector or something else. It runs, but very rough. Very loud ticking noise.
tell me i have the same ticking and i think its my injectors. . and very rough idle, hard start and bad mpg. . sometimes white/grey smoke
I would put a couple cans of 2 stroke oil in the fuel tank if it smooths out then it's your FCA . Have you checked your oil level bad ijector will wash down your cylinder walls and fill the crankcase. Oil analysis is a good way to go also. Did you do any flashes for the white smoke on start up? 05's were known to do that? Hope this helps
injectors removed and everybody tells me at my millage 115000 i think it was my injectors will fail sooner or later so thats that. . my shop may fix my injectors or i go with new ones. . ( in finland we usually rebuild cr injectors) and i want to go with some bigger nozzles. . please tell me what good mgp nozzles i can get and what power i may get 62/12 htb2 turbo 50psi smarty no cat and i will buy a liftpump. (fass or beltdriven?) and some good hint about performence nozzles please. . but will i get bad mpg then? somthing near stock mpg would be nice think my stock have been bad for a long time
