Few days ago I had my VP44 changed due to an abrupt failure resulting in engine shutdown and no restart. Had the following codes 1688, P0254, P0602 and 1693. Got in the truck this morning after getting back from the shop yesterday and my fuel pressure light did not go out when I turned the key on, prior to starting. Still didn't go out after starting the engine. Put a direct reading gauge on and lift pump pressure is normal, so it is working. Must be a bad pressure switch for the light. I have a Smarty that is set to program 5 and in the past never really had a smoke issue. Now the truck surges at idle and there is lots of black smoke when taking off or accelerating from a low Rpm, say 12 to 1300. There is also a pronounced flat spot while the smoking is going on, which makes sense. No codes set in the ECM.
Went back to the stock settings, much better but still surges and smokes a little and now has a check engine light on, but there are no codes set.
Anyone have any ideas.
Thanks
Mike
Thanks
Mike
