It's not quite as hard as suggested above. You can use the complete 24 valve engine except for the P pump, gear housing, pump gear, injection lines. You need the relays for the fuel shut down solenoid, and it is better to use a mechanical lift pump but there are fairly good electric ones out there.
Lawrence used a 2001 Ram, which is extra hard because it does not have a crank position sensor. Thus, he had to make the cam position sensor work in the P pump's gear housing. The complete ECM is still there, and it is too stupid to know that the engine can't run without an injection pump
It does know that the VP44 is brain dead for some reason
All the lights, gauges, speedo, and tach work fine. As the Beach Boys should have said, she's real fine, my 359
. . . especially with the P pump. His Ram has the 24 valve short block and head, and yes the block has a hole for a mechanical lift pump.
However, I can assure you that the conversion is not a bolt-on weekend project. Lawrence put some beautiful workmanship into the conversion, and it shows in the result. Of course, the P pump is not exactly out of the box, either
