Injector questions
What makes more smoke, the BOMB or the HOSE?
Where to drill for EGT and Boost fittings?
ACoyle
Super Moderator
1) Does anyone know where I can get the PDF files that I have seen referenced for installing the DD injectors?
2) Are any special tools needed, besides the well discussed crows foot or modified socket? I'm concerned about a reference to an injector puller and a connector remover?
Thank You
Andy
I don't know if you can find a .pdf file, but if you search the forums... several people typed out their instructions... one I can remember was Vaughn Mackenzie.
No special tools are needed.
The injector puller: use one of the short bolts that hold on your intake horn. It is a 10mm, about four inches long. It screws down into the middle of the injector, then use a standard screwdriver to gently pry the old injector out. If you try to reef it out, you could drop the little washer off of the injector. The washer really can't go anywhere, but it can be a bear to get out. It must come out! A new washer will be on your new injector.
Connector remover: I think you are talking about the tube between the high pressure fuel line and the injector? I did buy a little screw-on tool for this from Cummins, about 20 bucks, but lots of people use a needle nose pliers. If you use the pliers method, be careful of the threads.
If you can't find anything on a search, let me know... I will mail you a photocopy of instructions... I think I have about three different sets in my garage.
I just used a flat-blade screwdriver and gently pryed out on the cross-over tube... just make sure the injector line is loose enough to pull out of the way with your hand, then the cross-over tube prys out very easily. You must make sure the cross-over tube is pulled out of the way before you yank on the injector... otherwise you're bummin' with damage to the tip of the cross-over tube.
Andy,
I have the PFD file that you want... . Send me your email address and I will email it to you.
Doug S.
-- email address removed --
