Injector Replacement Poll
Has your common rail engine required any new injectors?
  • Yes
    Votes: 175 20.1%
  • No
    Votes: 694 79.9%
  • Total voters
    869
CP-3 (Injector Pump) Replacement Poll
Clutchless shifting?
rbattelle
Please answer "yes" if you've had at least 1 injector replaced, "no" if you have not had any injectors replaced.
I was just curious what sort of injector failure rate we're seeing.
-Ryan :)
I don't think there is an issue with the 305/555 engines. I have two of them with well over 150k miles combined. I think that when they went to the 325/600 power ratings the problem came up. In fact, so far I am inclined to think that maybe just the '04. 5 and early '05 trucks are suspect. I certainly could be wrong though.
I didn't vote yet as my '05 goes in for a bad injector diagnosis tomorrow.
I had one injector replaced at 12000 miles, it started showing signs at 7000 miles. It made things better, but still not quite right. I think I still have at least one more bad injector.
I have had two replaced so far. Dodge called the other day and said number three has arrived so I will make a appointment for next week. The ones that have gone bad so far are: #1,#5 and now #6. :(
34k miles and I'm thinking I need a whole set. Something a little bigger and better ya know ;)
-Scott
PS, no failures with the stockers.
dkosheba said:
What are the symptoms of a bad injector?
I second that question.
Should the injector lines be smooth? I heard line 1 shakes a little bit but the rest should be smooth. Will you notice higher egt's with a bad injector? Lower fuel economy? What else should we look for? Is there anything that can be done to prevent an injector failure?:mad:
34k and no problems yet.
4800 miles on the '05, #3 was found bad. The tech claimed that most of the ones he had seen were #3 for some reason. He also mentioned that failures seemed sporatic and he had not had any "come backs" on replaced injectors.
No problems on my 2 '03s, 150k+ combined :)
My failed one was leaking fuel. This would cause it to start rough and smoke. It also had a noticably shaky idle like it was missing, and it was. I do not have gauges but I bet egt's were up, un-metered fuel will do that. The truck seemed to run normally off-idle but was really bad in gear at a stop light.
Number six replaced at 35000 mi. The noise was a knock ,cackle- clack, just off idle. Now its quiet just like new... ... ... ... . JIM
none changed for me, but i suspect i have a weak one [i think #4] but i won't have a dealer look at it until summer and i will check the torque on them myself when the weather gets nicer [spring]
Swapped, not replaced
Mine had rod knocking type sound just off idle at ~25,000 miles. Found to be #6 cylinder by deactivating. SWAPPED #6 with #3 injectors and problem is gone. Can't figure out why it would have fixed anything - but it did.
Mathew
