Engine/Transmission (1994 - 1998) injector torque
2nd Gen Non-Engine/Transmission Shocks again
Engine/Transmission (1994 - 1998) 94-98 Injectors
need to know the torque on the line into the injector . It came loose this weekend started missing , tightened it, but I don't have the values.
Lets see, if I remember right, using a crows foot w/a torque wrench requires using a formula to get the correct torque. Boy its been a long time for that one so check it out before you do it.
Floyd
move the crows foot to the right or left so the distance on the wrench is the same or figure the extra length in a ratio and proportion . but I don't think it's exactly 22 lbs do you I think there will be a plus or minus as everything else is.
