INJECTOR up-grade ?????
Step bars or running boards ... which do you prefer?
bug shields & pyschotty air system?
I'm considering buying the bosch 275 injectors and I'm a little confused about what is called "matched sets". What is the manufacutring process of injectors and why will the characteristics of one differ so much from another; pop-off pressure and flow charistics? Aren't these injectors tested by the manufacturer before they are put out to market? What is the acceptable tolerances or pop-off pressure and flow rate or restriction of these animals off the assembly line? Considering the stock injectors are not matched sets, as I have been told, and there is such a wide difference in mpg reported from one person to another(with the same model an year truck); are these differences caused by the stock injectors? I thought Bosch was the ultimate in the injector manufacturing process; at least that's what I've gleaned from watching educational TV or did I miss the lateist special? Just what can I expect from a set of injectors that are not considered a "mached set", and what recourse do I have if they do not preform to expectatiions; is it a shot in the dark? There must be some specs that they are guaranteed to meet even if there is a slite difference between one to another.
[This message has been edited by arar (edited 03-17-2001). ]
If you want the best quality, contact Diesel Dynamics www.dieseldynamics.com
1999 2500 4x4, auto, 3. 54 LS, HD241, Quad cab SLT, Blk Sport Pkg, 16x8 Eagles, 285 Bridgestone AT, Amsoil, 80/100w lights, Valentine One, DTT TC/vb, DD2's, DD TTPM, Isspro gauges.
1992 SC400
1978 Mooney 201 IFR
What he said... ... . ^^^^^^
2K, 2500, Quad, SB, 4x4, 3:54LSD, A/T, Reese 15k 5th slider, EASLEY BULL BAR, WESTIN NERFS, TA's, 9000's,Cummins 505 ECM, stealth DD2's, Bully Dog Boost & elbow, ISSPRO pyro, boost & transmission, Turbo Lifesaver, JARDINE 4", DTT VB,TC,TC SAVER and AUX COOLER, PAC BRAKE, MAG HYTECH TP& DC, AFE filter onboard. Taylor Wing and Gear Vendors on order
pullee #1 26' Arctic Fox 5th
#2 22' car hauler w/ 76 Pinto 392cid or 68 Cyclone GT Cobra Jet FB
NRA-LIFE, VFW-LIFE, SoCSA-LIFE, SASS
