i THOUGHT SOME OF YOU MIGHT BE INTERESTED IN THE INJECTORS i HAVE BEEN RUNNING IN MY TRUCK THE LAST FEW YEARS WITH DRAMATIC POWER INCREASES. I went down to Wentland diesel and had them set up my pump-I had recently installed the power wagon injectors and complained of a power loss. I brought them my old injectors and they told me that the aftermarket injectors I had replaced with power wagons were a 300horsepower marine injector-no wonder for the power loss since the swap. They removed the power wagons, reinstalled the marine injectors and all brass hardware, set my pump down to only 10% over factory fuel setting and adjusted the timing, idle, smoke and diaphram. Now I have the same power I used to without all the extra smoke and exhaust heat. I think that after having these two different injectors in my truck that the marine injectors are a far better way to go-more heat, but WAY MORE POWER, especially on the highway-these things come alive after 50mph! my truck ran 82mph in the 1/4 mile with the power wagon injectors, but is way faster now. My EGT's in 5th gear with 3. 53 in the pumpkin are as follows: 400 deg/2#boost @50mph, 500deg/6#boost@60mph, 550deg/10#boost@70mph, 600deg/14#boost@80mph, My to end is 95mph-EGT goes to 900degrees them settles down to around700degrees-boost is constant around 20lbs. This injector setup lets the truck pull harder through the gears and seems to allow you to have more usable throttle before finding that flat spot where you must shift up. Seems like higher RPM's to me. my figures were taken at 3000 feet @ 35 degree temperatures. When the ice and snow are off the highway (May) I will run these speeds, and get readings up here at home-5000 feet. The part # for these injectors is one higher than the power wagons. -they are a Bosch injector. By the way anyone want to buy a used set of power wagon injectors with less than 800 miles on them?
