INJECTOR UPDATE
Power Wagon injectors, and off highway fuel questions
speaker size
Piers,
Thanks for the help. Sounds like someone is finally taking the time to helpout the first fo the first gen trucks. Thanks man we really appreciate the support.
later
Don
Ok the new injectors sounds great, what other add ons do you have, and would I benefit from those new injectors. Also what about heat ? The Hp your getting from the PW injectors would do it for me, but I can always use more POWER #ad
. And how much ?
Kyle
1985 DODGE 1 ton Crew Cab(imported from California with no rust) W/8' box converted to 4X4 in 1999. Converted to a non-intercooled 1991 Cummins Turbo diesel & 5 speed Getrag in 2000(wife can't drive a stick :). Freshly rebuilt and balanced Cummins. Rebuilt Injector pump and tweaked. 4:10 gears, limited slip rear end, 205 transfer case, 16" Goodyear GSA Wranglers and LE Package and a Sony CD Stereo. Next add-on some “Banks” toys ! Wish Dodge would build a new Crew Cab in 1 ton. Last year for the Crew Cab was 1985. If you want to know why I did all of this, 2 kids, one on the way and I can't stand Ford and Chevy. Kyle Hoover ,Fruitport, MI.
Sounds good to me i like the sound of 40 psi but what are youre egt readings ? If the egt's are controlable I'd be very interested!!! Keep on BOMBING Murfman
Hello everyone I just got back from BD on saturday,after testing the Lucas injectors that Piers found. All I can say is WOW these are 10 times better than the PW's. I now get 40 lbs of boost on flat ground with no trailer. My truck had 242HP and 610torque on the dyno the way I had it with the PW's. We could not do a comparison on the dyno with the new injectors due to the optical rpm sensor failing after the first dyno run. The difference in power is huge though. I would say that I'm around the 290hp and 750torque range.
88 GMC CREW CAB 4X4 89 6BT,NV4500,NP205,16CM,K&N,3. 5 EXHAUST,BD PIERS SPECIALS INJECTORS
The egt's are higher than with the Pw's,and to do any towing a intercooler would be a must,I do not have one yet. The highest I've seen the pyro is 1275 pre turbo,thats in 5th holding it to the floor going up hill. And they do smoke a little. As far as mods Look at my signature. Timing is at 1. 65mm.
While I was at BD they also installed the stock 89-91 injectors. They ran better than the PW's,and made more boost. 35psi verses 32psi with the pw's. Piers said the stock 89-91 injectors make about 20 more HP than the PW's.
Well I was wondering , wear might one such 89 guy find Lucas injectors ? I am starting to do some upgrading. .
2000 Dodge 2500 4x4 Cummins 5 Spd.
1989 Dodge 250 4x4 Cummins Auto. FatMac
BD has them,thats where I got mine.
88 GMC CREW CAB 4X4 89 6BT,NO INTERCOOLER YET,AUTO METER LIQUID FILLED GAUGES,NV4500,NP205,4. 10's,35 BFGA/TKO,6" LIFT,DETROIT LOCKER,16CM,K&N,3. 5 EXHAUST,BD PIERS SPECIALS INJECTORS
