Injector Upgrades
WHO's Got a FUEL PRESSURE Gauge?
Air Conditioner Clutch
I just installed the Poweredge EZ w/ boost elbow and I am still drooling. Just wondering what kind of kick in the A** going to Stage II injectors will give me. Can I expect the same kind of results as the EZ? If so, the drool may turn into a foam. In all my years playing with hot rods and race cars, I never would have thought I could have this much fun with a stinkin' ole deezal!
Will - -- email address removed -- - 98. 5 3500, 24v, auto, 4. 10, fold-away gooseneck hitch, Poweredge EZ w/ boost elbow, K&N Filter, Isspro 50# Boost, EGT, transmission Temp gauges mounted on A-pillar, & more to come!
38ft United Expressline X-Treme Race Car Hauler weighing in @ 12000# loaded
Other Bad Habit:
'87 Pro-Street Buick Grand National, 272cid Stage II Buick V-6, SINGLE turbo, 1400hp, 1200ft/lbs @ 24# boost
Best 60ft: 1. 11
Best 1/8 mile: 4. 99 @ 142mph
Best 1/4 mile: 7. 70 @ 179mph
And Lookin' For More!!!
So I'm A Turbo Man!
Boost On!
get the DDIII's and you'll be slobbering foam--
add the Power Edge box and you'll be spittin'foam & your EGT's will climb when you hammer it when on the #3 setting & a little more manageable on the #2 setting
add the HX40 & 4" exhaust and you'll be fully rabid... ... ... chris
I wouldn't add anymore power until you address the transmission issue.
But DDII's and EZ are 299hp to the ground on a Mustang dyno.
I've got to agree with Chris and Eric.
The injectors make as big a diff as the EZ... . The PE is a whole different story... Once you go past the EZ, your AT will be wheezing, big time, if you put it to the wood very often..... With just the EZ, it will last for quite a while..... Get the transmission upgrades, even on a stock truck, they make a world of difference... . As far as which injectors, think about the smoke issue, before you make the jump... . #ad
Colin
2001 Quad,4x4,AT,4. 10LS,LB,Loaded enough,stock,mostly... . 65 Chevelle sedan, Hella nice driver, 53 Nash Rambler Convt,1 of 653 built,[not a Metro], GM drivetrain, injection, and auto/od
Specialized FSR PRO Stumpjumper,Cannondale F2000, Loaded
MTD Lawn tractor with flames
12' fishin' boat, loaded. .
thanks guys for bailing me out--totally overlooked Bent6's sig--on the transmission upgrade, ya got to do it just like KD & CC said or your slobberin',spittin' will be replaced with tears as that thing will turn to mush with all that power--thanks again KD & CC---chris
My bad guys! Forgot to mention the planned transmission upgrades before anything else. I can tell with just the EZ that the stock TC clutch will turn to dust in no time.
I have the DD2's and the EZ with my DTT VB.
This thing flat hauls a#$!
My Dyno numbers bear out that PSD's and Dura Maxi-pads don't want to mess with my 3500.
However, If they are also 'chipped', you should go with DD3's and a Hot PE!
Y2K Awesome Black LB 3500 QC SLT, 24Valve ETC ISB, 4x4, 4:10 LSD, DTT Custom prepared Auto transmission VB, Power Edge 'EZ', DD2's, K&N, Polished Stull Billet Grill/Fog inserts, Chrome Smitty-Built Step Rails, Mopar Chrome-Tipped Mud Flaps, A-Pillar mounted West-Tach Turbo/Pyro/Trans Temp gauges, Rancho 9000's, Diamond Plated Tool Box, + a bunch of other stuff. Fact:The First Fords' had 'DODGE' Engines! The new PSD's need them!
Don't forget DC will void your warranty on the whole truck. Experience again!! haveing too much experience sometimes sucks.
1999, 3500, 6x6, slt, auto, 3. 54, Qd cab, ISB cummins, towing 2001 26RKSS Tahoe 5th wheel, 1999 120hp 1800 bayliner.
They cannot legally 'void' your warranty unless they can 'prove' the failure(providing you have one)can be directly attributed to your aftermarket modifications.
Our 5. 9L 24valve Cummins engines are an awesome machine, capable of tremendous upgrades(ask H. V. A. C. )
However, if they really wanted to, they could even 'void' your warranty for not letting your 'turbo' cool down after driving it!(They have the higher paid Laywers, you know. )
Anyway, I think the congressional 'ACT' is called the 'Magna-Carta' or something like that #ad
Robby- that's what I thought too. But, it doesn't work that way. DC can and will void your warranty. Maybe if you have a good dealer you could get away with things, but if they're ignotant or just plain jerks the warranty will be gone. I know from experience. I suppose I could ahve taken them to court, but for the thousands that'd cost it wouldn't be worth the repair. BTW, it was for an injector pump. I had Cummins put one in and it's ran great ever since.
1998. 5 2500, 4x4, SB, Red Sport, Agate Interior, Quad Cab, O. H. Console, Auto, 4. 10 LSD, Trailer Tow and Camper Special Packages, Mopar Aluminum Nerf Bars, Spray In Bedliner, Pioneer/Jensen System, 255/85's, Bd Adjustable Preformance Box w/boost module, Boost Elbow, 4" Exhaust Split Into Two 3" w/5" cans, K+N Scotty Style, Exhaust Blanket, Bill K's Valve Body, Mopar Tow Hooks, Factory Fog Lights, Front Bumper Step, 55 watt Back-up Lights, Etc, Etc... .
I thought I had a great dealer too, they even suggested I put in after market injectors, then they voided the warranty on my whole truck not just the engine. Everyone says they can not do that but they did. If people give you the good advice that DC can not void your warrany then these same people should help you fight DC's warrany issues. Sorry but on this one your on your own as I have found out the hard way. Only good thing that came out of this is it reinforced my feelings about dealers of any kind and big company's. I have the ability to do mechanical work on my own and V-W Motors of Cooperstown ND will never get another dollar from me. I will buy after market and none name brand parts when ever possible. This truck had better last me a long time because I will never buy another Mopar product. The thing that gets me the most is I was a very loyal patronage to mopar and when I needed them the most they they left me to hang. Sorry for my venting but had to let somebody know.
Ron
With 95000 miles on my truck, the warranty is about to be a thing of the past - being a drag racer, I am used to being my own warranty station - BELIEVE ME!
Will - -- email address removed -- - 98. 5 3500, black, 24v, auto, 4. 10, fold-away gooseneck hitch, Poweredge EZ w/ boost elbow, K&N Filter, Isspro 50# Boost, EGT, transmission Temp gauges mounted on A-pillar, & more to come!
Other Bad Habit:
Best 60ft: 1. 11
So I'm A Turbo Man!
Boost On!
I think all three (GM, DC, and Ford) are pretty much the same when it comes to warranty work. I saw several posts on www.ford-diesel.com about how ****** the owners were at Ford for doing lousy work and voiding their warranty. Many said they would never buy another Ford product.
If you plan on bombing, then you need to be you own warranty station.
Charles
2000 QC 2500 4x4 LWB ETC/DEE Anti-Spin 3. 54 Trailer Tow, Camper Special, DD1's, Practical Solutions boost module, Westin chrome nerf bars, Rhino Liner
My Toy
1969 Toyota Land Cruiser FJ40
350 TBI, Turbo 400, ARB lockers front/rear, 4 wheel power disk brakes, 4. 88 ring/pinion, 3 speed transfer case, full roll cage, Warn 8274, MRT 36 bolt beadlocks with Super Swamper Boggers (16x35x15), Saginaw Power steering, custom bumpers/fenders/nerf bars/skid plate, GM tilt steering column, 6 point roll cage, RCI racing seats with 5 point harness. Conquered Tellico and going to Moab this May. Loves to be pulled behind the Dodge and pass the powerjokes going up hills.
