Injector?
USB cable for Smarty?
Quick transmission question nv5600
I want to upgrade my injectors but I dont want to touch anything else. What would be the injectors I could use w/ out changing the pump or that the stock pump could handle & who makes or modifies the best? Thanks
These are the guys I'm going to use... .
Dynomite Diesel Performance
17631 147th ST SE #10
Monroe, WA 98272
Phone 360-794-7974
Fax 360-794-6890
Open Monday-Friday 8am to 5pm
PACIFIC TIME
I'm going to put a set on my 05 when I get around to it for pulling my 5er...
my vote goes to formula one you send him your entire injector he replaces the tips and pop tests them and make sure everything is in perfect working order before he sends them back
just to throw another company into the mix. Industrial injection make a very good injector. they have never let me down. you can either buy a set directly from them or send yours to them to have them rebuilt.
I will second the vote for F1 . I just installed some Flux 2's (100hp) and they knocked . 68 off my 1/4 mile time! Rail pressure holds steady at around 23k and zero smoke or haze at WOT. :cool:
yes just about all injector upgrades require a better lift pump. unless you go for a small set, like 50hp or less.
if you have a small set of injectors the cp3 will handle it pretty well. all the numbers in my sig are from a stock cp3 setup. but a aftermarket lift pump is a must.
Gauge used for Fuel Pressure
What size gauge (PSI) are you using to watch the fuel pressure's & where are you hooking up too? Thanks
