injector
'89 Front Axle GAWR - Brake Parts?
Clutch Questions
does anyone know whaich injectors are Part #kdal59p9
tips are part #11 0433175040.
5 hole injector
Just had them rebuilt, pop test showed pop pressure from 3600 to 4000 psi.
are they a standard bosh injector tip?
pop test wa before I had them rebuilt.
anyone have a picture of stock injectors?
As soon as I can get my current ones replaced I will take pictures and post.
Holy smoke holes, batman. Those things ought to flow enough fuel for ya. My stockers were 4 holers with holes about 2/3 that size- and they supposedly flow about the same as the PWs. My EDMs you can barely see the holes. Spray anlge there looks quite different from the 6 holes stockers in the later trucks.
Daniel
A bosch KDAL 59p5 body with that 5 hole 0 433 175 040 tip would
result in a part# 0 432 133 875 injector otherwise known as the
185 powerwagon
cat trains
Ok, I stand corrected. But without a magnifying glass, the holes looked smaller on my injectors, for some reason. :confused: :rolleyes: Our stock 4 holers were supposed to flow about the same as the above shown injector, werent they?
Daniel
Daniel,
Must be the camera angle:D :D
Jay
ps... . tomorrow's supposed to be a nice day around here..... might give my 'experimentals' a try... ...
I took a look at the stock injectors that I pulled out of my 92 CTD and found the following:
The Body: 8965, kdal59p9. 169, 245bar, Bosch, France,
Tips: 9093 with 6 holes
Al
