injectors and plates
Electrical boost pressure gauge?
How many of you live in MO.
If I have a #6 plate installed, and then add stage 2 injectors, will the injectors still add the 80 h. p. they advertise,or is 80 h. p. increase only to a stock engine, and an engine with a #6 plate wouldn't gain as much h. p. since it's power has already been turned up.
1997 2500 4x4,Auto,Cal. motor 48 state intake,3. 54's,Amsoil throughout,DiPricol egt/trans temp/boost gauges,Amsoil air filter, stock plate slid all the way fwd. ,star wheel turned 20 clicks
Jerry:
I e-mailed you tonight on this question.
I apologize for the delay. My monitor
"Burned Out" a few days ago and I could
not receive my e-mail.
To answer your question, injectors will
ADD the H. P. advertised to whatever you
ALREADY have. If you are at say "250 H. P"
now and you add the injectors that should
give you 330 H. P. "at the flywheel. " The
actual "rear wheel" H. P. will generally
be about 15-20% less than that, give or
take. I explained this in more "detail"
in my e-mail.
Hope this has helped you!
John_P
Red '96 4x4 2500 Auto 3. 54, TST #5, Major Pump Mods(By "Scheid Diesel") 370 Diamond B Injectors, Gov. Spring kit, AFC Spring kit, Banks Exhaust, Prime Loc, Cummins Chrome Kit,Psychotty Air Filter, Pro-Torque Converter, BD Valve Body, BD Pressure Loc, Isspro Gauges, Sendel 16" Alum Wheels w/ 33" BFGs
