Engine/Transmission (1998.5 - 2002) injectors selection
what is a good injector to uprade from my stock ones ? from my truck profile can anyone add to my question ?also any comments on the ebay injectors are they a good one to really question for and upgrade for my application
Have you done any work to your transmission yet?? With a Comp and injectors you are going to need to some transmission work.
EBay injectors are okay if you know what to look for. You want to make darn sure you are getting real Bosch injectors. . watch out as they often say "manaufactured to Bosch Specs" or some other BS.
i bought the truck in may and it had a new clutch not sure on the specifics at the same time not frequent that i slip it usually a low rpm in fifth with a matting of the accela rator will slip it . but i am just looking for the rush of more more more more ya know so i want to buy the injector that will put out the most mmmmppphhh if you know whasts i mean hey thanx alot guys for the comebacks. and suggestion. just trying to cross this bridge first i will post the results till then keep smokin?
Not everyone wants to spend $500+ on a set of injectors- all you need to do is swap the nozzles yourself. Some people don't realize that the only difference between the stock and performance injectors is the higher flow nozzles. Swapping them is easier than even pulling the injectors (though you still have to pull them to swap the nozzles)
IF you want a simple inexpensive upgrade, see my sig, or the ad in the classifieds group buy section.
It sounds like you want more than a little increase in injector size. You will surely need to upgrade your clutch as you can already slip it. You could probably go as far as Mach 2. 5's without needing to do to much with your turbo but you will need to pay attention to your egt's.
