GWS,
I have heard that larger Injectors actually put less of a strain on the injector pump. Although, I think all of it is just speculation. Nobody really knows, except maybe Bosch.
The only problem with the Fueling boxes that use the fuel pump wire to connect is the tell tale nick in the wire that could void your engine warranty. Other than that, they give you more bang for your buck.
I tried DD3's here in Colorado. The cold wasn't the problem, it was the altitude. Less air means more smoke.
98. 5 2500 QC LB 4x4 5spd, white. BFG 285x75x16
Cummins 24v w/ TST PowerMAX w/EGT and Boost gauges on A-Pillar. VanAaken CPC. K&N In the factory air box. Stock Injectors, Stock Exhaust (Geno's Muffler Eliminator). Re-routed breather stink tube, 2WD-low kit, SnugTop, JJ Stainless Running boards, Tow Hooks, Bushwacker Street Flares, and a Cup Smoothie.
83,000 miles (1/10/01)
