Ok, Finally breaking down and considering "Tapping the Magic Wire".
The choice is a tuffy because I really like the snappiness the VA box adds to the DD3's. This baby is pretty torquey, and the turbo spools quick.
Looking at the BlueChip APB box addition, because there is an adjustable knob you can mount to adjust the amount of additional fueling by the turn of the knob. Kind of simple & trick. Its supposed to add 85hp.
I do tow heavy, so am a little concerned about cylinder pressures considering the advanced timing of the VA and larger injectors.
The other option Im considering is going with the Diesel Dynamics Ultimate Fueling Module (basically an Edge Comp) and selling the VA. The DDUFM is supposed to have slightly less timing advance for less cylinder pressures, and it also obviously has lots of adjustable settings for different situations.
I know someone that had stacked a BlueChip 4-wire fueling box with their VA and ended up removing it because it was sometimes erratic, and caused the motor to stumble and set codes. Not sure what caused that...
So I'd like to know if it is ok to stack a Wire-Tap box with a VA? How many people have tried it? What were the results?
How reliable are the DDUFM/Edge Comp boxes? Do you lose any smoothness, or do they ever act up and cause your motor to run poorly? This VA has been flawless, and would like to keep the driveability, but add some ponies on the top end in case of rice-rocket attack. I would solder the wire connector if possible, and use a good ground either way.
So whats the best way to go? Van Aaken + APB Box? Or DDUFM and sell the VA?
Dont want to provoke box-wars, just looking for some more input before deciding.
Thanks in advance.
Thanks in advance.
