Engine/Transmission (1994 - 1998) injectors
Engine/Transmission (1998.5 - 2002) Simple question
Engine/Transmission (1998.5 - 2002) P7100 on a 24V?
Does anybody run the new era 435s in their truck. i was goin to buy the 370s but then i saw these. i am goin to build a high hp motor so i was wondering if anybody has these. thanks. also for a truck running 650 700 hp, whats a good turbo to get to drive on the street but also do some sled pulling? thanks.
370s are good for enough fuel up to around 700hp. But, if you use stock pistons, I'd suggest a set of DDP Stage 4s or some from F1. More power, with lower EGTs.
I'll let someone else suggest the turbo(s).
I don't know about the 435's but I'm sure they are a cheap injector like 370's. If your serious about making big power then don't skimp on the injector, now if you want a set to run as a second set that's fine. I run a set of 370's also but have a big set if Industrial Injection EDM's Dragon Flows. You can make 700 with 370's but it takes allot of pump to do that. I run a I. I. Tweaked 215 pump and 370's right now and that nets me 600 on #2.
The only street single I know of that will makes 700 hp without spray is a Silver Bullet, I run a lesser version, a SPS 66 with a ported housing, a Bullet update is an 07' project.
One avenue you could go down is find or buy a 215 pump and send it to a good pump shop for a checkout, tweak and check and run that till you run out of fuel. Then if for some reason you need more fuel you could then send it in for a P&B swap to 13mm's as the 215 cam works great with that setup.
Jim
I have heard good things about the new era injectors, there are better injectors out there though. For the price they are hard to beat. About the biggest charger you can really daily drive is an s300 hybrid. 66mm is a good size. Where are you planning to truck pull. I wouldn't be afraid of a prostreet 66 from HTT very good bang for the buck. The SPS66 from II is good also. The silver bullet is a nice charger, but spendy. I have ran 4 different chargers not including the stock one on my 12V puller. PM me if you have any questions.
I have the 435s and like them, they arent the cleanest but they are cheap power. They do run a tad on the warm side though, but nothing that water meth cant fix.
How comparable to the smoke of 370's are they? I loved the smoke :-laf , except the idle haze :rolleyes: of my 370's. What about driveability? Seem to remeber a fair amount of discussion about the "370 stumble". Don't think i had the stumble though.
Jordan
P. S. Getting up now to kick myself for selling them with my old truck. :(
