Taking a peek at timing
I've been working on figuring out the various scales of the things like timing, fuel rate, etc. Some scales have been easy - like engine RPM - that one was using the standard SAE scale found in the J1939 document: to get actual RPM from the actual binary number value, just multiply by . 125.
So, I'm taking a stab at the vp44 commands. If I apply the standard SAE scale to the timing command, I come up with the following:
1. The range allowed by the ECU software is approx. -6* to +60*
2. Warm engine, idling, I see the number 1440 (hex 5A0). That would work out to be 11. 25*
I don't know if this is right, it's just an 'educated guess' at this point.
