Engine/Transmission (1994 - 1998) Install gov springs
Engine/Transmission (1994 - 1998) Code Reader / 4" Flex exhaust
Engine/Transmission (1998.5 - 2002) Scheaffer Oils?
FWIW I installed mine through the side plug with a lil' help from a cummins wizard. Lay a small magnetic tray underneath the side cover on the pump, just in case you drop something the tray will probably catch it. Very easy through the side, i would rather do 10 through the side as opposed to 1 thru the top! Either way, just get the job done and be happy ;)
Curtis
41jay,
The last option-------
Let somebody else do it if you are worried about dropping anything. :)
The first time is the fun one. After that, it just take your time & do it. ;)
Your choice,
Have fun,
WAYNES WORLD
There valvers
Just got them in today 12 valve springs and one # 10 kit , it has a new break off screw in it but I don't want to use it I want to put a regular flat head or philops head back in it where do I get it so how do I or even do I put them in or just hold off alittle while untile I get the 3k kit
The cap screw is metric. Going from memory it's something like a M6 about 20mm long. Maybe someone else can chime in with the exact size.
