Got this kit online and installed it this last weekend
First of all the filter adapter is OK and the relocate thing has 2 filter holders. . I bought 1 extra online not knowing I needed 2..... grr!... Found one that fit at checker. The combo of the 2 filters total more area than the regular filter and lets flow happen better I guess. The amount of oil I put in equals to 4 quarts. . 1 to replace what you lose when you take off the old one plus 3 more to get the level up to full.
/webdata/photopost/data/573/medium/IMG_5085.JPG#ad
Mounted the thing to the bolt on the battery. It still has a little play but is secure. There is 2 in and 2 out ports so they supply 2 plugs.
This is where I mounted the cooler. The Air Dam has a screen in front of ot so there will be airflow through the cooler.
/webdata/photopost/data/573/medium/IMG_5087.JPG#ad
Now here is where I need to get one more valve for winterizing... I bought one where the red handle is, that is the pressure side and when closed, it is to bypass the cooler for winter. . Right now the vise grip is making the oil go through the cooler til I get another valve to go in its place. The lower pic you can see the opening in the air-dam
/webdata/photopost/data/573/medium/IMG_5091.JPG#ad
They have several filters they recommend for the kit.
AC ... ... ... ... . PF2
Lee... ... ... ... . LF1
Motorcraft... . FL1A
Napa... ... ... ... 1515
purolator... ... . PER1a
WIX... ... ... ..... 51515
All in all the kit is pretty neat... . I added 2 valves, 2 "T"'s and several more clamps to do the winterizing bypass. . Had about 18" of hose left over... No leaks, pressure is good and I notice just after idling that the oil is cooler after exiting the radiator...
