Holy cow my head is spinning here... ... lemme do a memory dump here and see if what spills out clears up things or makes them worse
Let's say for discussions sake the truck idles at 750 rpm (Rich picked that # and I kinda like it-remember arbitrary # here so if the true idle speed is 800 rpm don't send me hate mail). If you click the idler on-it raises the idle RPM probably 25 rpm or so. But it remaps (again Rich's learned speak
) the TPS output so that full throttle pedal is probably around 75% or so of normal-and everything in between is linearly spread over that range. The higher you turn the knob-the lower the maximum throttle value is-but the linear map still applies. You can still hit governed RPM just like everything was peachy keen. However I have not tried to drive there to see how things would react (ie trip the dreaded check engine light).
If you use the PS high idler to set a desired idle speed it will stay there-minus minor fluctuations from the AC clutch tripping on and off-but no mean jumps in speed like you'd get from a fixed throttle setting on a carbureted gasser.
In my experience (and it was so long ago that I can't even remember how fast I had the idler set) using it as a steady-state backwoods cruise worked fine until the truck tried to climb an incline. The computer feeds in throttle attempting to maintain engine RPM-just like it does at base idle or a fixed foot pedal setting. However somewhere in the loadup it gets confused-here's an opinion why-the ECM thinks you're idling along at rest-but it's gotta be getting a vehicle speed signal back through the PCM as well as seeing load factors all of a sudden from RPM and MAP sensor readings. To further confuse it, as I understand it there's a microswitch in the TPS that tells the computer the pedal is at idle. So in my esteemed opinion-and keep in mind my opinion and $2 won't buy you a beer in these parts
it's no wonder the check engine light comes on..... Something in the idle validation circuitry is the reason why the PS high idler has to be adjusted to a max of 1550 rpm with the trim pot inside. It will work at higher speeds-I had a little calibration error for a period of time
-but eventually you'll throw an idle validation code.....
Somebody else other than me should try using it as a backroad cruise to see if they get the same results-worst thing that can happen is setting an idle validation code and Check Engine light for a few keycycles. This way we'd know if my experience is valid or skewed by something unique to my truck.
If you're wanting a backwoods cruise control-the mechanical cable setup is the way to go. If you want a plug-and-play high idler-the PS solution is the best IMO. I guess I should have asked you that off the get-go George before I started raving about the PS box-for my application it was the hands-down best solution-but maybe not for you?
So who have I totally confused now with this ramble?
Jason
