I just received my Industrial Injection Super Phat Shaft 66 turbo yesterday. Reading through the directions, step #7 says to hook up the oil feed line, but not the drain. Then, crank the engine without firing until oil is seen coming from the drain port on the turbo. Question is, is this necessary? How do I crank the engine without it firing? (sure my '06 has the long crank time problem that hasn't been reflashed yet, but occasionally it does start like it should
). Is there a fuse I could safely remove to prevent the engine from starting without throwing codes, etc?
Thanks for any help... Eric
