The truck I purchased has a Fass Lift Pump, the hose at the VP44 ends with a steel swedged elbow and does not use a banjo. So, If I want to install an electric fuel pressure gauge, I cut that hose and install a 1/2" barbed adapter with the 1/8" port drilled in it to hook up a snubber and the gauge sending unit?
This will not mess with the flow of the Fass Pump?
I see no other way to install the sending unit, there isn't another port on the pump I can use is there?
Thanks ...Gary
Thanks ...Gary
