I don't have them on the truck yet, but I did wire some white driving lights up on the underside of my trailer.
Where I park it, there is NO light, and with the tires being under the deck, it's hard to tell where they are. I have to put them in the same spot within 3", otherwise I take out the neighbors fence, or the side of my garage. I also have some treated 2x12's that the tires sit on to keep the weather off them, and to keep the ground somewhat level.
I wired mine so that they come on and shine right down the side of the trailer and tires. They will only come on if the parking lights are on AND the truck is in reverse.
OH yeah, 1 wire for power, they ground thru the body/chassis. I used relays to take the extra load off my factory b/u lights wiring.
I used the factory b/u light wire at the drivers side taillight to trigger the relay, and I used an existing 12v switched power wire from my multiple towing harnesses (factory on hitch, 4 pin flat in bed, 7 pin in bed)
