Horsepuller said:
I am going to use this long weekend as my chance to install my gauges. I am installing a Westach combo (egt/boost) and a fuel pressure guage. I have a dual pod A-pillar mount, all from Geno's.
Here are my concerns.
1. Should I do this by myself or pay to have it done? I can do easy mehcanical tasks (I have a carpentry background), like changing the starter, brakes, oil and fuel filters, lift pump etc. but don't know much about 12V auto electric. I want the lights in the gauges controlled with the light switch. Both gauges came with most of the goodies needed to complete the installation.
You can do it! Drill, selection of drill bits, 1/4NPT tap, 7/16 drill bit for the hole (someone please correct me if I am wrong!), wrenches, sockets, volt meter, extra wire, wire loom, butt/end connectors, splice, wire tap, basic electircal crimper, coat hanger for pulling the wires/hoses into the cab, ability to read and understand instalation directions, a good botrtle of hooch, blah blah blah.
2. Fuel pressure gauge: I plan on using the NPT test port after the fuel filter to hook my hose to. Where should I attach the isolator. I have an 18" hose. Any better ideas?
Ditto the dirlled and tapped banjo bolt therory for the bottom ogf the fuel filter. You should also pick up a needle valve, and or a grease gun hose as an isolator. Now you will need extra 1/8 compression fittings, and 1/8NNPT couplers, elbow, and so on. This is part of the "Lay everything out" plan. Clear a spot on your workbench, or on the floor next to the truck, and start with the first part and visualize how everything will connect all the way to the gauge. If you need a part, put it on the list, and get a couple of extra. You can always return them.
3. For the boost and EGT I have to drill and tap my holes. Never done this before but directions look pretty easy. I will also need to buy a drill and tap set, any suggestions on brand, type?
EGT will need a 7/16 drill bit ( I think!!), and a 1/4NPT tap. Various instructions can be found via search for EGT gauge install. Some remove the four mounting bolts for the turbo, others just drill away. Using grease on the drill and tap, and cleaning the drill frequently will reduce the amount of shavings. Also a strong magnet under the point where you are drilling, and probe magnet to fish out the shavings works well.
BOOST - there is a port on the side of the engine block forward of the map sensor, and behind the fuel filter than can be removed. The hardware store will carry a reducer in the gas pipe section. I think it is like a male 3/4NPT plug with a 1/4 NPT hole. Galvanized is OK, stainless is better. There is also a boost bolt that can be had (from Genos as well I think) that replaces one of the intake manifold bolts. I personally started with the port on the side, and moved it when I got the bolt. You can also remove, and drill and tap the intake hat, but I think it looks cleaner with one of the first two options mentioned above.
I should've bought a Painless Wiring Kit from Geno's but it is too late now. Is this something that Auto Parts stores might carry?
Any overall suggestions? Thanks
Yes. Although you don't really need it for the gauges. You can buy a 4 port fuse block, 30 amp relay, some wire, and if you have a soldering gun, make one yourself.
Finding the wire for hte lights/dimmer is not that bad. I think it is the brown one on the back of the light switch. To do this, remove the dash bezel, remove the light switch assembly, and pull enough of it out so you can see the wires. With the volt meter set to measure 12vdc, attach the black lead to ground in a fashon that you do not have to hold it. Turn on your park lights, and while adjusting the dimmer switch up and down, check each wire until you get a reading that coresponds with the dimmer. That is the wire you want to tap into for your gauge lights.
On a personal note. Westach makes a nice gauge. The conenctions in the back have got to be one of the most mickey mouse things that I have ever dealt with. Straight pins with collars on the wire end that "Just slip on", and a little plastic sleeve to insulate it. I have issopro gauges on my truck, and installed a set of westachs on a buddies truck. PITA! The barbed hose fitting for the boost gauge did not build my confidense either. Get some small zip ties to use as a hose clamp. You might also want to think of upgrading to a heavier gauge hose. The aforementioned buddy, well I just had to replace his boost hose due to three holes in it, in less than 1 year. These were not wear holes, one looked like a cut, and the other two looked like splits. It was not in a position or area where it was subject to abuse.
Remeber, a shop will bill 2 or more hours to do this, and they are good at it. Plan on this being an all day event, and take your time to do it right.
