So I got the parts and going to put it in. Its too tight, needs to be shimmed. Order a shim kit and it comes with the shims that go between the bearings and the carrier. Is that the only way to shim these? I was hoping for shims that go between the bearing cups and the case. So how do I set this up without wrecking a bunch of bearings? Or can you buy the larger shims somewhere? I cant even get both of the cast selective shims in, so will it be ok if the bearing cups go right to the housing without them? #@$%!
