I'm installing a Scotty II that I bought from Diesel Power Products. Has anybody had trouble getting the plastic cone on the end of the filter to stay in place once you button everything up. The way I see it, your shoving it into a space that is tapered on one side, so it has no choice but to slip off the end of the filter. I've tried it at least 20 times. If you put it all together and connect it up, you would never know, but as you slip the hose over the turbo you can hear it pop loose. Each time I've been real careful and thought it stayed, but went ahead and pulled it, and it is cocked to the side. That's actually blocking airflow. I ended up not using the cone, but that sucks, seeing how I paid $250 for this. Regardless it looks like it will suck lotsa cool air.
Steve
Steve
