OK, I'm hoping that someone here has seen something similar before and can help me out. I'll apologize in advance for the long post... .
I had posted here before about having trouble with the gauges on the instrument cluster going dead and all the warning lights coming on. It would usually happen either when I started the truck, or when I let the truck sit and idle for a few minutes with the parking brake set. Basically, I'd get the Brake, Air Bag, ABS and MIL lights. Then the gauges would start going dead. The overhead display would show Ccd and the odometer showed 'No Bus'. Usually, releasing the parking brake would clear it all up.
I had previously thought it was a bad connection, so I checked the plugs under the dash and in the engine compartment. It finally got so bad that it would happen every time I started up, so I took it in to the dealer. The checked it out and determined it was a short in the cluster, so they replaced the cluster.
When I got the truck back, everything was working normally. I plugged my EZ back in and went on my way. Later that night, when I went to start the truck... . the same thing happened again. Then when I let it sit and idle, same thing as before. I tried repeatedly after that to try to make it happen again, but I couldn't recreate it. I was thinking that it could possibly be something wrong with the EZ, so I unplugged it... . but it ended up happening again after the EZ was removed.
So now it's been at the dealer for a couple of more days, and they've been over all the connections and haven't found anything that looks wrong and they haven't been able to make the same symptoms appear again.
Does anyone have any ideas about what to check now??
Edge said they could swap my EZ for a new one if I wanted, but they've never heard of one causing this problem.
I'm completely
and was hoping that someone might have some suggestions for me.
Thanks,
JM
I'm completely
Thanks,
JM
