Instrument/Dash Bezel Replacement
Incorrect EGT Probe Install
The DR has cooked up something Differant??
Does anyone out there sell a replacement dash bezel? I am trying to locate a good place to put three 2-5/8" guages and am thinking about modifying the bezel but would like to get a spare to work on.
Also, does anyone sell a dash mount 3 guage setup in the 2-5/8" variety (only seen 2-1/16" from autometer).
Thanks!
Those are stick on covers... I am looking for the entire bezel replacement so that I can cut & modify one to fit some guages.
As for the 2-5/8" gauge pods, they currently dont exsist. Autometer will probably never make them unless enough people want them. I think it also has to do with the space available. The 2-5/8" gauges dont seem much bigger but when you put them side by side and see how much more room they take up, you will see Autometer did not make a pod for them
I checked a couple of bone yards in the area-no luck. They said it was a hard item to come by. :(
I have also made some 2-5/8" gauge templates - they are hard to fit in... I can get them in the hole in front of the shifter (standard) if I remove the little compartment thingy. They would be difficult to see when in gears with the shifter forward.
I guess if I can't find a replacement dash to modify then I will have to go with 2-1/16" guages.
Thanks for the input!
