If you look below the PDC and left battery you will see the control relays. The 2 small push on wires on the front of the realy set can be simply pulled off. Now, why would you want to unplug them? It is cold enough in Ohio to need them. They aid cold starts and reduce smoke at startup and smooth out cold engine operation. They quit when you drive away. What's not to like?
