Intake horn bolt torque
Best place to buy 03-04 injectors?
Code P0243???
kblranch
Just installed a GDP intake horn and need the torque specs for the four mountlng bolts. Thanks in advance.
Service Manual states 18 ft-lbs on page 14-91. However, I would start at 10 ft-lbs and probably go no higher than 15 ft-lbs. Those are small diameter bolts...
18 ft lbs is normal for an 8 mm shank bolt. Follow the factory specs. I would recheck them after a few heat and cool down cycles
