I am planning on doing something with the intake, probably just the RE-0880 and maybe a pre-filter. I currently have the factory box with the fender connection pulled. Using thermocouples, I have been taking temperature readings at both the inlet of the box and out side the box where the RE-0880 would be mounted. I am quite surprised the temps aren't higher. The inlet of the factory box at 60 mph is 3-5 degrees F higher than ambient. At traffic lights or other stops it raises 20 degrees above ambient. Outside of the box it is again 3-5 degrees above ambient however at stoplights etc. , it is 30 degrees above ambient. Still not bad. The past few days have ranged from 80 -100. I never got a temp higher than 120. Matter of fact, when I arrive at work and let the turbo cool at idle, the temps would reach 100 and then rapidly drop and slowly rise. I suspect the clutch on the fan causes the fan to start spinning around 100.
Now for my question (the bombs) Next week I plan on ordering gauges, EGT and Boost as well as the pillar from Geno's. Does anyone have any install tips? This is my third ram, 96,98,01 but 1st diesel. I understand it to be safest, as far as breaking probe, to mount the probe after the turbo such as the down pipe. How about the Boost Gauge, Is the general idea to mount it in the elbow, which is connected to the intake manifold or is it better before the intercooler.
Thanks in advance,
Bob Ballard
http://www.geocities.com/robertballard_22655/Rampage.html
Pics of the diesel will come after the front is lifted 2"
Thanks in advance,
Bob Ballard
