You need to remove the bumper, radiator, top brace with the 45 degree angled struts going to the lower support. Either remove or swing the condenser out of the way. The intercooler inlet and outlet pipes are wider than the upper parts of the bracing at the sides. Therefore, you have to lift slightly, and move one side of the intercooler forward, then work the other side out.
To remove the radiator, turn the drain plug and pull out. It helps to spray WD40 into the recess to lubricate the o-ring. If the o-ring on the plug tears, you will have to replace it to prevent a leak. The o-ring is 9/16” ID, ¾” OD, 3/32” thick. Then take the hoses off the radiator. To remove radiator and intercooler hoses, it helps to work a tool into the joint to free the rubber from the hose fittings. I like the Sears Craftsman cotter pin remover. It is like a blunt ice pick with the last inch bent at a right angle.
