I am curious with the volume of lift pump issues on these forums,, a design or specification issue with DC I assume,, why aren't the lift pumps purchased directly from cummins better, more relable? than the pumps spected out by DC??? With the amount of problems with those pumps one would think cummins would have a more robust replacement available along with a pressure regulator limiting pressure to 15 lbs. . under all conditions. .
I just had another brain f**t,, hey maybe we should hook up parallel lift pumps with a check valve setup to prevent back flow with a DTDP switch on the dash so if one goes out we can just switch to the backup... :--) what do you think????Oo. Oo. Oo.
