CyberRanger
Howdy y'all!
I searched the forum for an hour & cannot find anyone else who has had this problem...
We have a 2002 2500 4x4 QC w/ the HO Cummins, 6 spd, 3. 55 gears. It has approx. 11K miles on it & so far we have done only about 200 miles of towing, but it does get about 725 mi/wk of mtn driving. The truck is completely stock except for a Tekonsha Prodigy brake controller. We average about 17. 5 mpg for virtually every tank. My wife drives the truck to & from work w/ about a 2200 ft difference in altitude between our home & her work.
We drove from Colorado to KC Saturday along I-80 & then down I-29, running about 81 mph most of the way across Nebraska, w/ about 1000 lbs in the bed. About the 3rd stop (a new puppy was along requiring more frequent stops) the engine refused to idle down below 1400. Engine temp & oil pressure were normal. In fact, other than the fast idle everything was normal. Our mileage had been near normal so far & has been since this problem surfaced. The problem went away as soon as the truck was shut off & restarted. The same problem reaccurred 2 more times--the second time it didn't want to idle below 1250 & the last time it didn't want to idle below 1150. The only commonality was that the truck had been driven for more than an hour at a time at or above 55 mph. The first time it occured we'd driven for about 90 min at 81, the second time about 80 minutes at 81 & the last time at 55 or more for about 105 minutes. We stopped twice in between the 2nd & last time, w/o the problem occuring. Each time the problem would disappear as soon as the truck was shut off & restarted after several minutes. Ambiant air temp was roughly between 32ºF & 40ºF & it was dry.
I need to call Sunflower Dodge or Cummins here in KC to see if they can identify this problem, but I thought I'd see if anyone on on the forum has had a similar problem & solved it, so I can go to Dodge or Cummins a bit more informed. We have had zero problems w/ the truck & love it to no end.
It doesn't affect the driveability of the truck other than it's a bit annoying when parking or driving slow.
