I have an intermittant low power problem. Seems to happen when its hot outside. I've had the truck for 2 weeks so I don't know how long its been an issue. Sometimes its very energetic and sometimes its lethargic. One day I strugged on the 101 in NoCal, 2 days later I drove I-17 from Phoenix to Flagstaff (steep grade, 100-120F) and had no problems! No smoke, just feels like its not getting enough fuel.
Fuel filter was suspect at first and replaced with no change. Lift pump changed with new Cummins dealer part. Fuel shutoff solenoid replaced after it failed to draw current.
Dealer suggested pickup screen in tank might be clogged. Maybe this is related to my fuel level sender unit being totally inaccurate (but low fuel light is accurate)? Or could it be air in the lines/loose connection?
Should I start by dropping the tank and checking for trash in the tank or a blocked screen? Or should I start by rigging up some test gear?
Currently no guages are installed in the truck but I plan to get on that soon.
Thanks,
Brian
Thanks,
Brian
